New Plan
jasminel
Hi, my plan was ending Sept 18. I wanted to go for the 90 day $120 with province wide talk, unlimited global texting, and 2gb data. I added it to my account a few days prior Sept 18th, but I'm now still being charged the same as my first plan for the next cycle. Is this an error?
I'm also very confused for the $78 balance I have on my account
Mary_M
Retraité / Retired
Retraité / Retired
Hey @jasminel
Thank you for reaching out to us !
I understand that you requested a plan change, however it did not take place. This is actually a small glitch in the system but don't worry - I'll update it for you. Pleas private message me your phone number and I'll send you a confirmation once the change is done.
Cheers,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
sportymi
I had this before too. Moderator @Mary_M or @Shazia_K will help you with this.
Rockdaddy22
Should definitely be an easy fix in the morning, hold tight.
nishufan
Hi @jasminel
  You can send a private message to @Shazia_K and @Mary_M to look through your account. They will reply you when they at work.
 Thanks
skidoomaster
Hi @jasminel. Issues like these are glitches in the system that occur from time to time. A moderator will help you resolve this tomorrow morning @Shazia_K @Mary_M
