04-24-2019 03:12 PM - edited 01-05-2022 04:34 AM
I just wish my plan from a province-wide to Canada wide plan it has not worked because I can't receive calls and I can't make calls because it says I do not have a current long-distance plan I've missed my interview because of this
04-24-2019 03:16 PM
I find that anything with PB takes three times as long as it normally should, If your account page says that you are signed up then just be paitent, it will happen.
04-24-2019 03:14 PM
@Tawilli wrote:I just wish my plan from a province-wide to Canada wide plan it has not worked because I can't receive calls and I can't make calls because it says I do not have a current long-distance plan I've missed my interview because of this
If your account status is active, try the lost/stolenphone trick to re-provision your plan features.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is up to 48 hours. Good luck.
