01-07-2018 07:56 AM - edited 01-04-2022 03:15 PM
When i try to send a text i get the error.
"Sorry, your current plan does not include US Roaming text messaging. To update your plan to include US Roaming texting visit publicmobile.ca/selfserve"
What does "International Text" mean if i can't use it to send texts while in the US?
Thanks
--hollyb3rry
01-15-2018 09:52 AM - edited 01-15-2018 09:54 AM
Thanks all for your replies!
01-08-2018 04:27 PM
@hollyb3rry please note that buying Add-ons is a two-step process. Details here. Please make sure you complete both steps.
01-07-2018 08:52 PM
"international" is only refering to the destination of the text message. It'll only work in Canada with your regular plan that includes texting, or with a roaming add-on while in the United States. While in other place in the world, text messaging with your Public Mobile service will not function.
01-07-2018 01:53 PM
You need to purchase an Add-on
01-07-2018 10:58 AM
if you know your pin and you have a creditcard registered you can simply call 1-855-4PUBLIC, no need for wifi
lots of info in this post https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Learn-all-about-US-Roaming/ta-p/75772
01-07-2018 09:24 AM
@Rabbi wrote:@hollyb3rry just to let you know if you wont to text mms/image etc, you need to add text & data that shulde work
@hollyb3rry you could use Hangouts, Whatapps or Skype and more with Wifi
01-07-2018 09:07 AM
01-07-2018 09:06 AM
@hollyb3rry wrote:Thanks Rabbi, makes sense i guess.
I see the add-on in here for $8 to add voice, or $8 for text, or $15 for both. I suppose i can pull in to a McDonalds or somewhere where there's wifi, and add the add-on for voice calling if i needed it, but how long would it take before the add-on worked on my phone?
you have also the add on of $20 for talk & text & data
01-07-2018 09:02 AM
@hollyb3rry its have to work right when you add it for 10 days
01-07-2018 08:35 AM
01-07-2018 08:10 AM
International Text is you can text from canada to International
but if you are not in canada you have to buy a romming text addon
