I have international text in my plan, but my international texts say "not delivered"
04-15-2020 01:35 PM - edited 01-05-2022 10:22 AM
Hi there - I'm from Canada and am trying to send a text to Slovakia. The number has sent a text here, so their end works, but I've put in their country code and it says "not delivered" and that it failed to send immediately after I press send. Is there a reason for this? Am I putting in the numbers wrong? I even put in 011 before it, and it still didn't work. Thank you!
04-15-2020 01:44 PM
The correct format to text any country outside of North America would be 011 which you have it right. For Slovakia, the code would be 421.
So try 011421 + your number and see if it goes through.
You can always try downloading Whatsapp if you have not had it. It is a great app to call/chat with anyone in the world that also uses WhatsApp!
cheers
04-15-2020 01:40 PM
@gumbaline it seems that you dial 011 +421 + number to call Slovakia. See link
https://www.howtocallabroad.com/slovakia/
Stay safe.
04-15-2020 01:38 PM
@gumbaline wrote:Hi there - I'm from Canada and am trying to send a text to Slovakia. The number has sent a text here, so their end works, but I've put in their country code and it says "not delivered" and that it failed to send immediately after I press send. Is there a reason for this? Am I putting in the numbers wrong? I even put in 011 before it, and it still didn't work. Thank you!
@gumbaline Did you try replying to the original text that you received from Slovakia? If no, give it a try and report back if it doesn't go through.
04-15-2020 01:37 PM
- 011 - US exit code; dial first for international calls made from the USA or Canada
- 421 - Country Code for Slovakia
- Phone Number (may not begin with 0) - 9 digits, area code included for fixed lines
