07-04-2019 09:00 PM - edited 01-05-2022 05:43 AM
please help! I can't send or receive picture msgs or MMS msgs. Are my apn settings maybe wrong?
07-05-2019 10:41 AM
You could try steps 1-8 here.
Resetting your MMS
May be a bit different if youve upgraded your androis os.
07-05-2019 12:05 AM
@jessica_quintal wrote:Should I restart my phone or do anything else to it?
@jessica_quintal A restart wouldn't hurt. After the restart test to see if you can receive an mms text. Don't forget to turn data on.
07-05-2019 12:03 AM
07-04-2019 11:59 PM
@Great Neighbour
It's not in order because I had to divide the entire thing into two screenshots. But these are my settings.. some of them I've never seen before
07-04-2019 11:59 PM
@jessica_quintal Change APN type from default to the following:
07-04-2019 11:56 PM
07-04-2019 10:48 PM
@jessica_quintal wrote:please help! I can't send or receive picture msgs or MMS msgs. Are my apn settings maybe wrong?
@jessica_quintal Post a screenshot of your APN settings.
07-04-2019 10:38 PM
Have you compare your apn to the official apn setting? Normally its the issue.
If its same, use another phone to test your sim card, or another working sim on your non working phone.
07-04-2019 10:37 PM - edited 07-04-2019 10:38 PM
@RossN wrote:@jessica_quintal your data has to be on to send or recieve mms even though it does not use your data what plan are you on
To be accurate, MMS does not use any of the metered mobile data. It does use mobile data that is routed through the MMS proxy.
07-04-2019 09:09 PM
07-04-2019 09:05 PM
