I have a blackberry 8310 unlocked but I only get sos and no signal
eliesalame
The Blackberry is unlocked,
ID: shows the SIM number
SIM: disabled
Network: disabled
network subset: disabled
Service provider: disabled
Corporate: disabled
it is a rogers BB, and the mobile network still appears as Rogers, is there something else I have to do make it work?
Thanks
Seb
@eliesalame : sorry but your phone is not compatible because it's only a 2G phone.
http://www.gsmarena.com/blackberry_curve_8310-2050.php
Martin
Legend
Legend
Hello,
Frequencies cannot be changed. When the phone was being manufactured, certain hardware was installed and enabled so that the phone could operate on pre-set frequencies.
As far as checking the frequency of your phone, it works on a 2G network, whereas PM's is the more modern 3G. As a result, your phone is incompatible with PM's network.
eliesalame
how do you check the frequency and how can you change it?
If Frequencies are NOT the 850/1900 for 3G
1700/2100 for 4G LTE, THEN Handset will NOT FUNCTION
3G is the Bare minimum required for overall usage, if only 4G, you'll have to be in a 4G LTE covered area to receive service
makkahn28
Hello. If BB 8310 Doesn't support BB10 iOS, then that's why it's not working. Data, Txt, etc support ONLY BB10.
Also, PM does NOT have 2G GSM Fallback, only 3G: 850/1900 MHZ
4G LTE: 1700/2100 MHZ
4G LTE Advanced: 700 MHZ ( Telus Has Not Built up this Infrastructure Yet, and Handsets Need to have this Specific Frequency to Use that particular LTE Advanced Hardware
