05-14-2015 06:02 PM - edited 01-04-2022 12:38 PM
Hello there,
My Hand Phone is BLU Dash 5.5 What type of Sim Card Size do i need to order? Thank you so much.
05-14-2015 09:46 PM
I think the thread you are refering is a phone that was only 2G.
The phone of @johariwindows support 3G but he must have the correct version
For Public Mobile, OP need the D610a HSDPA 850MHz / 1900MHz
05-14-2015 09:30 PM
@Cyber @johariwindows
I may be wrong but I think there was another thread where a customer was talking about this phone and it was determined that it wasn't compatible with Public's network?
Here's the stats from GSM arena
05-14-2015 06:40 PM
Do you have the Dual-SIM version of this phone ?
I suggest you to order Tri-Punch SIM card. This SIM can be broken in all SIM card format.
