09-16-2021 12:39 PM - edited 01-06-2022 03:23 AM
I'm sure I've previously seen my usage for the monthly 250 mb but am not seeing it now. That makes me think I am not 'getting it' and using it...
09-16-2021 03:00 PM
@khuber if you login to My Account, check the Usage log, filter by date (have it set to start from your current cycle start date to today) , then focus on the Web type traffic and you can confirm if you have used really used up the 250MB
Since 250 is not a lot, try to disable Mobile data when not in used. Also, try to change the setting to save data, like turning on Data Saver, make sure OS update and App update are set to only download on Wifi, etc.
09-16-2021 01:20 PM
can you check it out your history data has left, maybe you used all data..
if you left your data is will be stop work until next cycle will be renewed, or you can buy Add-on if you data,
at public mobile Prepaid Service No fees extra charges,
visit Here link to Managing Your Data Usage, and to save it your data..
09-16-2021 01:09 PM
@khuber If you don't see data in your Overview, that means you already used up all that data for your current 30-day period. It will re-appear after plan renewal.
09-16-2021 12:46 PM
@khuber : That likely means your phone has used all the data. It's not much. OS and app updates could easily consume that. Even syncing cloud accounts and such.
Turn off all those cell data options and turn off your cell data when not needed.
