I forgot my email address for self serve account.
Manion
Manion
Yes I have. I spoke with customer service and got everything cleared up thankfully. Thanks for trying to help me. I appreciate your time.
@Manion
Have you ever created a self serve account before, if not you can register for one here:
https://selfserve.publicmobile.ca/self-registration/
If you have registered before, then @softech has you covered.
@Manion
First try to Reset Password link there, you can try to put in any possible email and see which one will bring you to Step 2 of the process
If you are really unable to reset it that way, then you will need to open ticket with PM Support for them to sort it out for you
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
