I do not get a text to confirm my identity when using app or Web
Amin5
When i try to log in via App or Web, it kets me a text is sent to confirm my identity. I do not get the text. I am having a hard time loging in
Amin
Amin5
Yes it works
Thank you.
Amin5
Yes i did. When you attempt a couple of times it works.
Thank you
hi @Amin5 did you ask for port in phone number?? are you receivimg inbound calls??  I think porting was not done.  Call the porting support team and get it sorted first. I have sent the number to your comments inbox
hairbag1
@Amin5
after a couple of failed attempts to send code via SMS, you should get option to have it sent to your email.
