07-15-2022 01:10 PM
I cant make any phone calls or text all of a sudden. Im an old customer. What’s happening? In my account it says my account is active.
anyone else with this issue?
do we all have to order a new sim card since they are with telus now?
thanks
07-16-2022 12:45 AM
Hi, thanks for your reply.. and no nothing works even when i reset my phone.. 😕
07-15-2022 02:14 PM - edited 07-15-2022 02:24 PM
@44 @Margaret0 First try rebooting or toggling airplane mode on/off. You can try your SIM in another phone to rule out any device issues. Another option is to try setting the network mode to 3G/WCDMA.
edit: If you're both still unable to get service, I would send a private message (since chatbot is also acting up) to CS_Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-15-2022 01:56 PM
I don't have any mobile either. I noticed 30min ago.
07-15-2022 01:15 PM
@44 Hi no new sim we were always part of the Telus family does anything work?
