07-11-2022 07:33 PM
I tried to put my sim number to activate but it says use valid sim number. I copied below the barcode and the number on the sim card but nothing work. Please help
07-11-2022 08:51 PM - edited 07-11-2022 08:54 PM
London Drugs will activate the SIM for you free and hassle free before they stop offering this service.
I would suggest you take it back with your receipt and have them activate it for your.
It needs to be activated first then power off the phone before you put the SIM in your phone.
If you are porting your old number, you will need to leave the old SIM in your phone then activate, power off the phone, swap the SIM and finally power on your phone.
07-11-2022 08:29 PM
@bluesanta well that makes no sense at all if you dial *611 does it say do you have an active account?
07-11-2022 08:18 PM
I just paid $10 for the sim card. an hour ago
07-11-2022 08:15 PM
@bluesanta wow thats crazy so they didn't activate your account? what did they charge you?
07-11-2022 08:12 PM
I just bought this an hour ago in london drugs
07-11-2022 08:11 PM
@bluesanta so this can't be a new sim card?
07-11-2022 08:10 PM
yes
07-11-2022 08:09 PM
@bluesanta ok lol lets start over you started activation process and you can't get past inputting sim card number? so you didn't make it to the payment section?
07-11-2022 08:06 PM
I'll just buy another sim card. It seems someone still calling messaging this number. thank you for your help.
07-11-2022 08:04 PM
I have galaxy note 10 and I can use call
07-11-2022 08:02 PM
@bluesanta hi if you didn't activate that would be impossible, you must have an iphone and are sending imessages
07-11-2022 07:57 PM
I already can text messages and I didnt even activate my sim card. Is there someone using it other than me?
07-11-2022 07:54 PM
yes
07-11-2022 07:54 PM
I tried to reboot my computer clear the cache use incognito but still dont work. I even used my phone
07-11-2022 07:39 PM
07-11-2022 07:37 PM - edited 07-11-2022 07:39 PM
@bluesantahi try clearing your cache use a different browser use ingognito mode reboot your computer and try again dont forget a referral code
