05-21-2018 02:00 PM - edited 01-04-2022 04:20 PM
I can receive all texts (SMS and MMS). I cannot send SMS. All other services are working fine (data, phone, etc.). I have an iPhone SE running the latest iOS.
09-05-2019 10:07 PM
I have a iPhone SE and wasn’t able to send Text with images (MMS?). Reading the solutions in the forum I was able to fix it going to settings >general >reset >network. 2 minutes solution. Thanks for your help
05-22-2018 03:07 PM
Thank for your response.
Please can you try your current SIM card into another phone?
I am waiting for your response.
Cheers
Abdoulaye
05-22-2018 01:45 PM
Thanks for the suggestion. I've tried that force reboot multiple times with no success in resolving the SMS issue.
05-22-2018 01:11 PM
@chakri264 wrote:Could you please try pressing the home button and the power button together and force turn off your phone? Once the phone is restarted see if the problem is resolved??
I had the same issue few months ago. This trick really worked. Hope it works for you too.
05-22-2018 01:06 PM
05-22-2018 01:05 PM
Hi Aubrey993,
Thank you for reaching out to us.
I am sorry to hear that you are unable to send outgoing text messages and I can reassure you that I'll be there to help you with this issue.
In order to look into your account and for security reason, you need to provide the current Public Mobile phone number and PIN. Otherwise, you can provide 3 elements of the following information: Date of Birth, Address with Postal Code, Home or business contact number, Commonly called numbers or text messages (SMS), Last top-up amount and the date, Last booster purchased and the date or Email address.
I am waiting for your answer.
Cheers
Abdoulaye
05-22-2018 12:50 PM
let us know what's the solution when you find out!
05-22-2018 12:49 PM
Thanks for the response. I am connected via wifi. I turned off iMessage application and tried sending SMS. It did not send. Any other suggestions?
05-22-2018 12:13 PM
Hello Aubrey993,
I am sorry to learn that you are unable to send SMS text message.
If your iMessage software has been turned on, you've to be able to connect either on Wi-Fi or data available into your phone. Otherwise, you can turn off the Apple application then test if you will be able to send outgoing texts.
Cheers
Abdoulaye
05-22-2018 12:03 PM
Ok thanks. I tried those solutions. No effect. SMS messages still won't send.
05-21-2018 09:45 PM
@Aubrey993 I'm late to the game here but if you are still stuck it's possible that a ”force" change of your SMS settings may solve the issue.
•Go to Settings
•Then go to Mobile networks and select a network other than Public Mobile, Telus, or Koodo
•When you exit the menu the phone should lose the network.
•Repeat the process and select Public Mobile as your mobile network.
This procedure will force the update of the message centre number. You can verify it in your message settings.
Also you might check for a carrier update which will show if you go the Settings >> General >> About.
05-21-2018 03:10 PM
OK, tried those solutions with no effect.
05-21-2018 02:56 PM
@Aubrey993 wrote:Ok thanks Shawn. I did search the community and confirmed that my phone settings are correct ( as far as I know). Messages - send as SMS is active. Also Messages - send & receive is set to my phone number.
Hi @Aubrey993,
This might be something to do with your phone (iPhone I assume). Before you contact the Moderators, try the following:
1. In Settings, go to Messages and turn off iMessage. Then, in Settings, go to FaceTime and turn off FaceTime. Finally, reboot your device and enable the two options again.
If the above still does not solve it, then try:
2. Reset your network settings (Settings > General > Reset Network Settings)
05-21-2018 02:31 PM
05-21-2018 02:11 PM - edited 05-21-2018 02:12 PM
@Aubrey993 wrote:I can receive all texts (SMS and MMS). I cannot send SMS. All other services are working fine (data, phone, etc.). I have an iPhone SE running the latest iOS.
Sorry thought you were havingissues with MMS. I don't have any experience with iPhone on PM I am sure someone with some suggestions will be along soon.
