07-15-2018 11:22 PM - edited 01-04-2022 06:27 PM
07-16-2018 12:20 AM
Tell me If that works bc I will prob have to do the same thing when I go stateside
07-15-2018 11:49 PM
Ok thanks I'll check in the morning.
07-15-2018 11:34 PM
if your addon expired i believ it needs a day to reset. I would message the mods and ask them to activate teh addon for you especially since you have the funds already. in the morning i would also try to purchase the addon.
worst case I would buy the closest addon that works then explain to the mods what happened, and ask them to change you to the addon you wanted.
07-15-2018 11:33 PM
@myhandyman Many have reported this as a problem because the system does not allow you to purchase the same add-on again before the 10 days expiry date.
Your only option is to either buy another US add-on such as talk only or wait until 10 days fully expire. If 10 days already passed, check it in the morning.
