09-19-2021 03:18 PM - edited 01-06-2022 03:24 AM
My outgoing calls are being restricted time and again, though I have Canada wide unlimited call plan.
09-19-2021 04:14 PM
09-19-2021 04:08 PM
@hairbag1 My mistake, your right. Didn't see who you directed your reply to. I should be more careful next time 😃😃
Carry on!
09-19-2021 04:02 PM
@Quigley wrote:@hairbag1 I'm pretty sure that the OP said that they have the plan with unlimited Canada wide calling option.
@Quigley...you're correct...but the one I responded to (An22), didn't mention their plan detail. I wondered if @An22 had the $15 plan with limited outgoing calls.
You're very likely correct about this one also though.
09-19-2021 03:56 PM - edited 09-19-2021 03:57 PM
@An22 you can receive incoming calls without issue?? Which plan do you have?
did you try rebooting your phone?
09-19-2021 03:55 PM
09-19-2021 03:41 PM - edited 09-19-2021 03:43 PM
@An22...if you're on $15 plan....log into your account and view My Data and Add-ons to see how many calling minutes you have used. Maybe you've run outta minutes in which case you can get the $5 / 500 minutes of Canada wide calling add-on.Those add-on minutes will get used when you run outta regular plan minutes and any unused add-on mins will roll over until you use 'em up.
09-19-2021 03:35 PM
I could not make calls either. Tried putting the 1 in front. No difference.
09-19-2021 03:21 PM - edited 09-19-2021 03:21 PM
try putting a 1 in front of the 10 digits number
it should work
