11-27-2025
12:11 PM
11-27-2025
08:15 PM
computergeek541
I cannot even login Public mobile with verification code to my phone. I have to ask for verification code sent to my email
11-27-2025 12:57 PM
Thanks.
11-27-2025 12:13 PM
but you can login with the code sent to email?
if you are getting the code via email, after login , go to Profile-> Manage EverSafe ID and check if the phone number is correct. Update if needed. But if you cannot get the code via sms and email, ask PM to check
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
11-27-2025 12:12 PM
can;t access your account so use this link to message Customer Support for their help...
