I can't use my data
Kashubjr
At first I thought this was just an outage however I haven't been able to use data in over a week. I pay for this data and I have reset my phone, I have tried internet solutions like clearing partition cache however I still can't use my data. I am prompted to sign into network every time I try and activate data but my phone has not been reported stolen nor have I been made aware of fraudulent activity.
Kashubjr
My 90 day cycle just reset. So I have 6000+ Mb remaining of data. I have so far used 157 Mb in the month of October trying to connect to data.
Jarvar
@Kashubjr
Were you able to resolve this issue? If all else fails, the next recourse would be to contact the Moderator team directly to find out what is happening if you have already tried the suggestions of those posted before me.
I hope you can find a solution quick as it seems like a long time without data and not knowing why.
Effort
Login to your self-serve portal and see if you have data still listed on your account. Once you run out of data for the month, it disappears from your self-serve portal until renewing.
Furthermore, once data has been spent, it simply stops working. There's no overage use and no overage fees.
will13am
@Kashubjr, if you have been successful in using the data before, that means there should be no issues with the phone set up or phone compatibility.  My sense is you have run out of data.  Login to the self serve and take a look at the overview.  What do you see on data usage.  If there is no mention of data, then it is all used up.  It is weird, that is how the account is presented when there is no data left in the cycle.
hairbag1
Log into your acct, look at My Add-ons and check the data remaining to make sure you haven't used it up already.
