03-31-2019 12:10 AM - edited 01-05-2022 07:02 AM
I just joined PM today. I got the $10 plan to start out with. It has 50 mins Canada wide talk. I got a new number from PM (not ported) I can make calls and send/receive sms but I couldn't receive calls. When someone tried calling me it says the the number is not equipped for incoming calls. Does that mean I need to include incoming calls in my plan but I have 50kins Canada wide talk? Or something's wrong with the phone? It's Nokia8 TA-1004. I'll appreciate your help. Thanks!
03-31-2019 12:22 PM
Hi! It's already working. I didn't have to do the lost/stolen phone. I'm not sure what happened but before I even tried doing that, someone called me and it went through! I'm glad. But thanks everyone for all the suggestions!
03-31-2019 10:41 AM
@Rain wrote:@Jessica_T I will try that and see what happens. Thanks
@Rain Any luck on that? Seems to help a lot of users out
03-31-2019 08:44 AM
03-31-2019 08:21 AM
@Rain wrote:I got a new phone and number. I did restart the phone twice.
Did you write a message to the moderator?
03-31-2019 08:19 AM
03-31-2019 02:22 AM
@Rain Try this trick. Report your phone lost/stolen in the self service account under Plans and Add-ons, Lost/Stolen Phone and logout. Wait 5-10 minutes. Re-login and report phone found. Reboot your phone. This seems to reset your SIM card and hopefully activates your plan/account.
03-31-2019 12:38 AM
@Rain You better contact the Moderator by sending a private message that is the envelop icon and to "Moderator_Team".
03-31-2019 12:27 AM
@Rain wrote:I just joined PM today. I got the $10 plan to start out with. It has 50 mins Canada wide talk. I got a new number from PM (not ported) I can make calls and send/receive sms but I couldn't receive calls. When someone tried calling me it says the the number is not equipped for incoming calls. Does that mean I need to include incoming calls in my plan but I have 50kins Canada wide talk? Or something's wrong with the phone? It's Nokia8 TA-1004. I'll appreciate your help. Thanks!
Not a phone issue. A phone can't make the network produce an error like that one. I think maybe system thinks you are out of minutes or voice not provisioned correctly by Public. I think you need to contact moderator_team.
03-31-2019 12:23 AM
Odd. Can you transcribe exactly what a caller hears? I'm assuming you're testing with another phone at hand.
Maybe your call forwarding permanent is on? Maybe you have a do not disturb setting on?
03-31-2019 12:21 AM
