I can’t receive calls
12-29-2018 03:49 PM - edited 01-05-2022 06:23 AM
12-31-2018 12:45 AM
__________________________________________________
Hi there,
I also experienced your same issue when I first signed up - in my case my number was still in the process of porting from Freedom Mobile at the time - to complete this process may take up to 24 hours in some cases, even if you may be able to use data / text already this is normal.
I would also make sure you've finished setting up your Public Mobile account online and activated your e-mail (not here on the community but the account page).
If this is already complete then you should take your SIM card out of your phone, power off for a few seconds then put it back in and boot up.
Let us know how it goes.
Best of luck,
Darcy
12-30-2018 08:19 AM
Ok thank you
12-30-2018 08:18 AM
@Ibrahim94 wrote:I sent private message to moderator yesterday but no one answer me 😠😠
Mod response times are apparently taking around the 48 hr and up range
12-30-2018 08:14 AM
12-30-2018 08:11 AM
@Ibrahim94 wrote:I port from freedom to pm
A new customer with a stuck port..
12-30-2018 08:05 AM
No I’m a new customer
12-30-2018 08:01 AM
@Ibrahim94 There is delay for moderator to fix the porting issue.
If your old provider still working, use it while they fix it, sometimes port failure old provider still work on receive and outgoing call.
12-29-2018 08:29 PM
I already sent it but no one answer me
thank you
12-29-2018 07:02 PM
Looks like you have a stuck port which will require you to send a private message to a moderator..
12-29-2018 05:07 PM
Yesterday
12-29-2018 05:06 PM
12-29-2018 03:54 PM
12-29-2018 03:52 PM
Yes yesterday
12-29-2018 03:51 PM
@Ibrahim94 wrote:I can’t receive calls but i can make outing calls
Did you port to PM?..if so when?
