I can't make or receive calls.
Deanna81
I was able to make and receive calls yesterday and after a couple hours I can't make calls anymore
DarkKnight_1000
@Deanna81
Try resetting your network settings.
For Samsung:
Settings → General Management → Reset → Reset Mobile Network Settings
For iPhone:
Settings → General → Transfer or Reset iPhone → Reset → Reset Network Settings
After that, test calling again.
If it still doesn’t work, you’ll need to contact Customer Support
click this link to contact them
than check your inbox when they reply in a few hours
@Deanna81
If nothing is working then check for outages in your area or dial 611 to see if your account is suspended due to nonpayment for this month.
Check my earlier response to troubleshoot.
Deanna81
I paid it yesterday. Everything was working fine and then stopped. Can't make or receive any calls or texts
Deanna81
I have done everything they have told me to do. I'm at a loss here. Nothing is working
@Deanna81
What is the make and model of your phone. Since 3G has been removed, you will need VoLTE to make and receive calls. Here is more information:
https://www.publicmobile.ca/en/get-help/articles/volte
Also check to see if there is an outage in your area:
https://istheservicedowncanada.com/status/telus/map#google_vignette
Are you update on your monthly payment?
Are you getting data?
Sansan
Did you just join Public Mobile?
Restart your phone and try again.  Is your account active and up to date?
