I can't login.
janradke
When I asked to for login info, I enter the correct info, however, a verification code is sent. When I enter the verification code, it takes me right back to the login screen, rather than my account. Please advise.
2 REPLIES 2
Outdoorsman
@janradke hi there have been some issues since the new upgrades,try using a different browser in private or incognito mode reboot your device if that doesn't help  you will
need the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
@janradke try this.. try using a Incognito mode or a different browser like Edge/Firefox/Chrome  and see if it works
if not, then you will need help from PM support:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
