02-08-2022 12:39 PM
Hi
So I have iPhone 12 Pro Max and I have tried blue tooth same problem I can hear people they cannot hear me but when using magic jack app no problem I took out the sim and put it back it resolved the problem temporarily but came back so it seems a network or sim problem should I reset the whole phone long process or change sim
thanks
kashif
02-08-2022 06:47 PM - edited 02-08-2022 06:48 PM
Can you try someone else's SIM card in your phone and test to see if people can hear you?
If still issues, check here for troubleshooting your microphone: https://support.apple.com/en-us/HT203792
02-08-2022 12:46 PM
Can you try your SIM in somebody's else phone to determine is it SIM or phone issue? Maybe your phone started losing contact with SIM as it worms up.
02-08-2022 12:42 PM
Hi @chaudhrycn
reset SIM, take out SIM, re-inserting SIM and power on,
try toggling airplane mode off/on,
try manually selecting network "3G only" or WCDMA only,
and Rebooting device..test it.
