10-07-2025 01:16 PM
I can receive texts, I have received texts and confirmation codes from others, why am I not getting these ones? I have contacted them and they say they have been sent.
10-07-2025 03:47 PM - edited 10-07-2025 03:51 PM
@will13am wrote:Give it a break please. Don't send customers on a wild good chase needlessly.
@will13am mine was a good guess.
It does take some time for a number transfer to fully migrate out to the various databases. You just might have to wait a bit unfortunately.
don't give false hope. @JoeCoin's port was done 2 weeks ago, the 2FA "delay" will be at max a week. so, it is not something further wait can help. It is either the device issue (which clearing app cache and reset networks could help) or PM system is not accepting the 2FA text (could be a non-Canadian shortcode)
10-07-2025 03:24 PM
@JoeCoin wrote:I am receiving 2FA code from PM. I am not receiving them from other companies.
Sorry my mistake. It does take some time for a number transfer to fully migrate out to the various databases. You just might have to wait a bit unfortunately.
10-07-2025 03:03 PM
@slusagm wrote:can you check what shortcode Crypto.com sent from? Non-Canadian short code might not work. You might want to ask them to send through other ways, Authenticator app or email
and To reset network settings on an Android device, go to Settings > System > Reset options (or Settings > General management > Reset on a Samsung phone)
10-07-2025 03:03 PM
10-07-2025 02:54 PM - edited 10-07-2025 02:57 PM
@JoeCoin wrote:I have completed a number transfer, about two weeks ago. I am on the app, I can't seem to find what you mean about updating credentials. All my info is up to date on my profile
@JoeCoin , click on the manage login tab. There you will see an option to update the phone number for where to send login 2FA codes.
10-07-2025 02:42 PM
10-07-2025 02:38 PM
I can receive calls. I can receive 2fa form PM. I am not receiving 2FA from Crypto.com.
I am using android, I reset my cache, I don't know how to reset the network settings.
10-07-2025 02:27 PM
can you confirm if you are getting incoming calls without issue?
and you can receive 2FA from PM? which exact companies you cannot receive 2FA from?
if you are using Android, please clear app cache for the Messaging app
Then Reboot the phone and Reset Network Settings and test again
10-07-2025 02:23 PM
10-07-2025 01:34 PM
@JoeCoin , are you able to use the resend code option and have it sent to email? If you have completed a number change or number transfer, the eversafe credentials are not automatically updated. You need to go into your online account, profile tab to update the credentials.
10-07-2025 01:29 PM
you meant you cannot receive PM 2FA or 2FA from other places like banks?
can you receive phone calls? if so, the port was completed. It is Normal that you don't receive 2FA for 3 to 7 days from other system, they have that in place to avoid sim fraud. After 3 to 7 days, you should receive all 2FA codes without issue
