Options
10-04-2019 09:32 AM - edited 01-05-2022 07:24 AM
2 REPLIES 2
Options
10-04-2019 11:22 AM
If you are using Gmail like abcdef@gmail.com for 1st phone, then you can use abcdef+1@gmail.com for your 2nd line, all emails will go to same abcdef@gmail.com account.
Options
10-04-2019 09:34 AM
Yes, you can self refer yourself. However, you will need to activate the second line under a separate account/different email address. You can use the same name and credit card for autopay, but need different email address to access 2nd line.
