I added data will it take effect immediately
goldi
Hi,
I have one GB data and i used it all I just added 3 GB more will it get added immediately and i will able to use it.
@goldi  Yes it should be taken right away from credit card when you purchase add on .
goldi
Do9 they automatically charge my credit card. Bewcause i do.t see that. It should show available data
Dunkman
@goldi
Yes, it will take affect immediately.  FYI, the data add on will expire after 30 days.
If you need extra data often, it will be cheaper to change plans to higher data plan.
@goldi  Yes it will automatically be used and kick in once your regular plan data is all used up . You also might need to reboot the phone first also
