12-08-2022 06:03 PM
I made a mistake and sent a text to stop all text to receive new deals and promotions how can I
12-08-2022 06:23 PM
Ok Tks I am still on the old rewards so might not be able to.
12-08-2022 06:22 PM
Ok then great to hear.
To get that other 1GB of data, you'll have to login to the Rewards portal first.
You'll see it there as $0 for 1GB
12-08-2022 06:18 PM
I believe for that you may need to log into your Rewards portal. (i may be wrong there... anyone?)
I'm on the old Rewards program so I don't qualify for the extra 1GB.
12-08-2022 06:18 PM
Tks I sent him a message
12-08-2022 06:16 PM
Tks I did get the Bonus already but was trying to get the 1gb with public points that is when I sent the wrong text
I don't know how to get the extra 1GB with the public points
12-08-2022 06:14 PM
Thanks I already got the Bonus Data just worried I won't get any other deals
12-08-2022 06:07 PM
If you did that, don't worry you'll still get the text message about all the free Christmas gift.
Just be a little more patient.
12-08-2022 06:06 PM - edited 12-08-2022 06:08 PM
To contact a Customer Support Agent, there are 2 methods. The 1st is the 'preferred' method, and the 2nd is said to not result in as quick a response.
12-08-2022 06:04 PM
@GigsDonna either u wait until Dec15 or send the ticket to CS_Agent about your issue.
