I CANT BAY MY BILE
Rahshaeladl2022
HI I CANT BAY MY BIL MY PHONE NUMBER TEMPORARY UPENDED PLEASE HELP ME TO BAY MY BILE
9 REPLIES 9
maximum_gato
@Rahshaeladl2022
It may be easier for you to pay by pm voucher thru 611 or calling 1 855 4PUBLIC and enter your 10 digit phone number.  You can also pay with your credit card thru 611 but you need to enter your 4 digit account pin #.
For info on where to purchase vouchers or use other forms of payment please read this post....
https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-t-Make-a-Payment-or-Update-Your-Card-...
Or use the muskbird.com link.
@Rahshaeladl2022
if your account was suspended over 90 days, then your account was in fact permanently closed
If less than 90 days, can you login My Account?  If so, login My Account, click Reactivate my plan and follow the steps
If you cannot login My Account, no worry, you can try to use the Reset Password link on My Account login page, or open ticket with PM Support
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
Right. Because apparently the payment somehow didn't go through. This is a prepaid service. If you don't pay, you don't get service. As mentioned, autopay can fail.
Adding - did all what?
Rahshaeladl2022
I DID ALL THIS BUT IT DOES NOT WORK
Meow
What IS your question???
Rahshaeladl2022
MY PHONE NUMBER IS TEMPORARLY SUSPENDED
dust2dust
Can you log in to your account? Do you know your 4 digit account pin? You can also buy vouchers online or from many stores and dial 611 to enter them. Or you can pay using the real time payments method in some stores.
@Rahshaeladl2022
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611  no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you  still have service and your plan renews today / tomorrow you can ignore this suspended notice
ShawnC13
You are asking people here to pay your Bill?
