Huge Phone Call Probelms
Optimus087
For the last 2 weeks, I have been experiencing the audio cutting out during my phone calls and the occasional loss of internet.
Is this a Public Mobile issue? Is anyone else having this problem?
hi @Optimus087
your phone should work with VoLTE without issue.  Check here to confirm
https://www.publicmobile.ca/en/on/get-help/articles/volte
I would also ask PM support agent to refresh your account:
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
Optimus087
Google Pixel 5.
I've reset the phone multiple times. I care most about the phone calls. I switched to the 3G network this morning and it seems to have fixed things but this shouldn't be a permanent solution
hi @Optimus087
voice and data issue could be a different one
what phone do you have?
But try Reboot the phone and Reset Network Settings
