09-05-2019 04:41 PM - edited 01-05-2022 06:53 AM
I have read other postings that state Huawei P20 Pro works for public Mobile. However, when I start the process of phone verification Huawei is listed but the model P20 Pro is not available to select. What does one do here?
10-01-2020 01:50 PM
Answering this question from a Huawei P20 Pro phone with public mobile connection. This works wonderfully.
09-06-2019 12:34 AM
@Tduggan wrote:I have read other postings that state Huawei P20 Pro works for public Mobile. However, when I start the process of phone verification Huawei is listed but the model P20 Pro is not available to select. What does one do here?
Saying p20 pro might not be enough info. Phone companies can make different vatiations of the model and not all might be compatible. What is the exact model number?
09-05-2019 09:51 PM
Checked the specs on the phone:
https://www.gsmarena.com/huawei_p20_pro-9106.php
Public Mobile uses the following frequency bands:
It will work with Public mobile.
When you activate your new account, you don't need to put in your actual model phone or even IME with activation. It justs activates the SIM card. You just put the SIM card in your phone afterwards once activated.
09-05-2019 09:51 PM
Are you talking about this?
09-05-2019 09:45 PM
Thank you. However that doesn't help me proceed. In order to set up an account you need to verify the phone compatibility and as the drop down doesn't give the model I can't move forward.
09-05-2019 04:43 PM
I'm using P20 Pro right now so I can confirm it does work. Also have a few P20's on Public Mobile
