Huawei P10
AlanFauchon
I can't find this model in phone compatibility chart. Has anyone used this model successfully?
DOA
You can find the P10 at kimovil.com.
Both the global and china version work with PM.
Luddite
@AlanFauchon You can also check your phone's specs against the requirements for PM.
Network Frequencies at PM
  • 4G LTE/LTE Advanced: 700 MHz, 850 MHz, 1900 MHz; 2100 MHz downlink with 1700 MHz uplink (AWS).
  • HSPA (3G): 850 MHz, 1900 MHz (UMTS).
Public Mobile has partnered with willmyphone work as the new compatibility checker. If you can’t find your make and/ or model here: https://www.publicmobile.ca/en/on/get-started, provide feedback directly https://willmyphonework.net/Home/ContactUs.
Jb456
Yes it works. Just has to be unlocked. Contact old provider that you got phone from for Unlock code if it's not UNLOCKED
