Htc one s
08-08-2018 08:50 PM - edited 01-04-2022 06:41 PM
I've scoured the depths here looking for proper apn settings from my old htc one s. I've inputed what I've found for other htc phones and now my data and texts work but I cannot send/recieve mms.
My imei number checks out as ok when I input it to check.
Can someone point me in the right direction with only minimal abuse?
Phones
08-09-2018 05:25 PM
08-09-2018 04:41 PM
@CS_Agent none of this is working.
I've factory reset the phone 2x. It makes voice calls, sends txts, accesses data on the web.and receives mms text. It will not send mms messages.
"Service denied "
08-08-2018 10:31 PM
To receive MMS you need to go into "Settings" Connections,Data Usage and turn on "Mobile Data". It might look different on your phone but the result will be the same. It's turned off by default. This won't cost you.
08-08-2018 10:13 PM
You are right. I was not thinking straight.
Last thing to try is do a network reset on your phone after using Android HTC APN for PM.
Some phone needs to do network reset after changing provider.
08-08-2018 10:02 PM
@popping wrote:Have you try this APN setting?
https://support.t-mobile.com/docs/DOC-14127
That's not for Public Mobile.
08-08-2018 09:57 PM - edited 08-08-2018 10:08 PM
@Notjosephstalin wrote:Wish it was that easy. Been all over that website.
HTC ONE S not listed there. I even looked at every variant of htc one but no help.
Last thing to try is do a network reset on your phone.
08-08-2018 09:55 PM
I believe APN settings for most Android phones are the same. So you can choose any HTC phone settings to look at.
Have your tried rebooting after making changes?
08-08-2018 09:24 PM
08-08-2018 08:55 PM
Go to this site to find the proper APN settings: https://apn-canada.gishan.net/en
