02-20-2026
08:33 PM
02-20-2026
10:10 PM
computergeek541
Hi to all!
I'm just wondering how can i use my rewards points? Can I use it to reduce my bill?
02-21-2026 06:21 AM
Thank you. I know it now
02-20-2026 09:15 PM
here's what to do when you accumulate enough Points and you wanna redeem them...
https://www.publicmobile.ca/en/get-help/articles/redeeming-public-points
02-20-2026 08:50 PM - edited 02-20-2026 08:55 PM
@beth0927 yes. each point is $1. but you need to collect to $20 points to redeem for $20 bill credit
and if you need to buy addon, check the rewards catalogue on My Reeards. it is cheaper to redeem for addon (the point value itself will be more when redeem for add-on, more than 1 Point $1)
