How to share same plan with others
Eltayb
I recently received a txt message to upgrade to 15GB 4G at $40/month. It says on the message that I could share the same plan with other but I don't know how?? This specific plan does not show online for everyone.
dabr
@Eltayb    The 15GB/$40 plan should be available during the activation process.
Eltayb
I can't find the same offer online for others to sign up for it.. I guess I should have worded my question better
dabr
@Eltayb   This plan is available when you log into your self serve account and clicking Plans/Add-ons, then 4G plans and scroll with the arrow for the $40/15GB and not $40/5GB.  If you replied yes to the text offer, then you will be switched over on your next renewal which is the recommended option as well if you decided to change plans from self serve instead.
The sharing part is only referring to you actually recommending this plan to a new potential customer you think might be interested in activating a new account in order to take advantage of this limited time offer.
hycm53
@Eltayb PM doesn't have share plan or family plan like the other provider such as Rogers, etc.
Outdoorsman
@Eltayb hi anyone can sign up for this plan but if you mean share your data you can't do that
