03-05-2025 02:55 PM
I am planning to leave public mobile because i am paying almost double after rewards pattern change.
So how can i remove payment method? I wanna remove my master card permanently.
Thanks
03-08-2025 04:58 PM
Same here
03-05-2025 03:06 PM
you might be earning less, but you sure you can save on another provider? earning less rewards still save me more compare with going to another provider
if you decide to go , ask PM to remove the card
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
