How to reach Customer support
JBBurl2023
Need to reach a customer support agent
@JBBurl2023
While you are waiting for a response from a CS_Agent. We can help you if it is a common issue? It is a lot faster.
eddieO
@JBBurl2023 To contact a support agent you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
