08-31-2018 08:36 AM - edited 01-05-2022 05:33 AM
Hello everyone How can I get the 10$ plan? Can I get also 2$ waive for auto pay for this plan ? Thanks in advanced
08-31-2018 11:25 AM
It is in the choices of plans on the application and does qualify
08-31-2018 09:26 AM
@Farjy wrote:Pick ready means ? Sorry little explanation would help a lot .
You're conflating two terms used in the post.
"Pick list" means a list of things to pick from. "Ready made plans" is the list to pick from in this case. You pick a plan from the list of available plans that are packaged together rather than the build your own a la carte area. I quite like the a la carte myself.
08-31-2018 09:13 AM - edited 08-31-2018 09:16 AM
If you have an account click change my plan and you will see a list of plans. Future date the plan change for your next renewal.
If you are a new customer during the activation process you will be asked what plan you want and there will be a list. Pick the 10$ plan and continue. If you are a new customer activating online and using a referral will get you and the referral an extra 25$ credit.
This helps s what the pick ready looks like.
08-31-2018 08:42 AM
08-31-2018 08:39 AM
@Farjy, the $10 plan is in the pick list of ready made plans. Yes, it does qualify for all the rewards including auto pay.
