How to fast forward or go to end of message in voicemail?
yoggee
I just ported from Fido to PM over the weekend.
I've searched the Community for an answer but I can't find it.
In Fido's voicemail, I could press 3 to forward 8 seconds or 33 to the end of the message. This is useful for those mandarin spam calls where I don't want to listen to the entire vm. Is there something similar in PM voicemail option?
Thanks.
yoggee
@TheOldVR
I read that link before I posted. It doesn't say anything about fast forward or go to end of message. It only says about Call Forwarding. That link is missing the Listen to Messages options which I later found in Telus voicemail Quick Reference Guide (since they are the same co). This chart is more detailed especially the part on "While Listening" & "After Listening"
https://assets.ctfassets.net/9mt4r6ro1ay9/4MNlTBalKUooe8kQEGcwkc/d003aa3439f623082c4d880e687112ca/vo...
@yoggee
I just left a message on my phone to check your question.
You can press 3 to fast forward message
You can press 2 to pause message
RobertQc
Thanks.
@yoggeeThis is not how to fast forward, but you can just hit 7 right away to delete the message, anytime, even before you heard the entire thing.
The second you hear its spam, just hit 7 to delete.
