03-24-2024 04:23 PM
Paid
app shows available to install
get error message opps problem, try again later
can’t buy another eSIM as app says to install the one I just bought but can’t install????
help please
cs has been less than useless
03-24-2024 04:36 PM
I never got a welcome email, I have checked junk and deleted. I just added eSIM to my iPhone 15 and no email either. It installed from app
03-24-2024 04:34 PM
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
03-24-2024 04:33 PM
@Judebabe So it didn’t instal nothing to delete then . But you can check your welcome email and try to scan the QR code to install the eSIM
03-24-2024 04:32 PM
But I get this
03-24-2024 04:32 PM
my app shows this
03-24-2024 04:31 PM
does not show I have an eSIM
03-24-2024 04:28 PM
@Judebabe If eSIM didn’t instal should be no need to delete it but you can check your sim manager in phone setting try to ensure PM sim is enabled or set to primary and “turn this line on “ is toggled on
There you can delete it too . But I think you just have setting toggle on that line and rebbot phone for it to work
