05-09-2017 10:00 AM - edited 01-04-2022 01:45 PM
Hello,
How do I check how much data my phone consumed on website. I checked the usage tab it gives you minutes and data. But for data it is only showing 30mb and I am on 4GB 3 months plan. I try to use the phone but I don't get any data at all. How can I get total data used for 3 months?
Thanks
05-09-2017 11:26 AM - edited 05-09-2017 11:28 AM
The data allotment shows up in the account as if it is an add on. So, if there is no available data showing in the add on tab, then all the data has been used up for the current period. The only solutions are to tough it out until renewal, buy add on data or ask a moderator to renew the plan off schedule.
BTW, the datawitness app is pretty good for tracking usage over a 90 day period. This app was built specifically for this service by a member.
05-09-2017 10:51 AM - edited 05-09-2017 10:54 AM
05-09-2017 10:50 AM
Thank you everyone, I checked the usage it doesn't show anything left but I am unable to see when data was used up?
I will get data management app. Does public mobile has their own app?
It would be nice to see when the data is used?
05-09-2017 10:44 AM
Like everyone mentionned get the My data Manager it is very useful and precise and keps track of everything that goes on.
05-09-2017 10:18 AM
I would suggest downloading a data manger for your phone, that way you could keep track of your data. You can also set limits per month and keep track monthly, or 90 days for some.
05-09-2017 10:12 AM
05-09-2017 10:08 AM
@tcsingh, if you login to the self serve and look down at addons that is where your data is listed. It will give you what you have used during this current cycle. If it is not showing there then you have used up your data for this current cycle.
