05-09-2017 01:22 PM - edited 01-04-2022 01:45 PM
Hi,
My account is suspended because the credit card I have on file is no longer valid. I can't log in,
I keep gettig a "Oops" Message regardless of reseting or account info. Is there any other way to change my Credit card? How long does it take for a moderator to reply?
Thanks.
05-09-2017 02:09 PM
Thanks Marie - can you make sure you can log in with my info? The last time it was reset it didn't fix it either.
05-09-2017 02:04 PM
@markis@13446
Yes thank you I saw your message. Currently looking into it 🙂
05-09-2017 02:02 PM
FYI solution did not work - I tried dif PC's. I believe it to be an issue with my account.
05-09-2017 01:33 PM
I took care of it! Sorry about the delay. Please view your inbox 🙂
