12-07-2016 02:15 PM - edited 01-05-2022 01:13 AM
I am new to public Mobile, can some one help me how to update username of my selfserve account to a new emailID
many thanks in advance for the help
12-07-2016 02:19 PM
Thank you all worked
12-07-2016 02:18 PM
After loging in, look for Edit Profile on the right. There should be an option to change username.
12-07-2016 02:17 PM
Hi,
You can get a new username at the following link
Login to selfserve with your existing username
Goto - https://selfserve.publicmobile.ca/Overview/my-profile/change-username/
Login back with the new username
Note your pwd remains same
Hope this helps
