How to change phone number?
Catherine12
@Catherine12
If you have not created a Self Serve account yet, you can do that here: https://selfserve.publicmobile.ca/self-registration/
Found under your "My Profile" in you Self Serve account:
@Catherine12
You can change your number up to 4 times per 30 days. To get 5 more selections of phone numbers choose a different locale or nearby locale within the same calling area to get more choices and go back and forth til you find the number you like.
 @Catherine12 : If you can log in to your self-serve account then click Change Number in the box of links below your name on the right.
