12-02-2023 09:27 PM - last edited on 12-02-2023 11:36 PM by computergeek541
12-02-2023 10:35 PM
12-02-2023 09:48 PM
This is Applied at the Payment Screen during Activation, did you type it in and apply it there?
Or are you under the impression it was not applied because you didn't get the $10 Credit yet?
12-02-2023 09:28 PM
If you activated already contact an agent.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
