12-02-2023 10:41 PM
Son is locked out of his account. Number has been ported successfully according to the port team. But he is still unable to make or receive phone calls. Port team says I need Public Mobile tech support. Is there a phone number for them?
12-02-2023 10:46 PM
@Nate1980 You can use this direct link to submitt ticket with support team
can send a private message To CS_Agents
12-02-2023 10:44 PM - edited 12-02-2023 10:44 PM
You can try getting back into account after an hour. Try reinstalling SIM card, reset network settings and rebooting.
If you need an agent:
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
