How to activate my account?
10-27-2020 12:56 PM - edited 01-05-2022 03:55 PM
10-27-2020 01:45 PM
@vc4 wrote:My account was blocked by public mobile. How will I accessed it?
If you cannot login to your self-serve account, try the "Forgot your password?" link on the login page to reset your password.
If you tried too many failed login attempts, PM server will lock you out for security. Create support ticket using the chat button at the right lower corner to get moderator help to unblocked your account.
10-27-2020 01:00 PM
Do you mean your self serve account ? Can you provide more information ?
10-27-2020 01:00 PM - edited 10-27-2020 01:02 PM
What do you mean blocked?
Is it a temporary block did to too many attemps?
You can just wait it out and in couple of hours reset your password, don't try to login
If it doesn't work contact mods
You will need to prove you are the owner.
If your line was inactive for more than 90 days then your account was purged
What kind if error do you get when trying to login?
