09-06-2024
12:31 PM
09-06-2024
12:33 PM
I want to subscribe for a plan that need to make phone calls all the time and want to know how’s is the service in Erin , Ontario , address is :
09-06-2024 12:41 PM
Erin has full 5G and 4G coverage.
You can check the coverage map here:
https://www.publicmobile.ca/en/on/coverage
Also, anyone using Telus/Koodo/Bell/Virgin/Lucky would be using the same network tower. So, if your friends use those, ask for their experience
09-06-2024 12:36 PM
Here is the PM coverage map and check on the signal in your area.
Also, PM will also connect to Bell towers if there are no Telus towers in your area.
