How may I change my community name?
omorphi
8 REPLIES 8
@omorphi you cannot change it yesterday and it looks like you can change it today yourself with the new Community update.  On the profile, there is a nickname field you can update
@hTideGnow wrote:
HI @esjliv   true,changing email on the old Community first
I just curious after the change, do we need to wait long to create a new Community account reusing that old email address.
@hTideGnow  - as soon as you change the email on a community account, the previous email is available to be used on another community account. It is pretty much right away.
@hTideGnow - It is just an option. OP can change the email to another email (if they wanna or able) on the existing community account.
HI @esjliv   but the problem is, if OP uses the same email on the current Community account, he cannot use the same email on the new Community account.
@omorphi  - or just created a new one and use the new profile. Remember to keep the email the same as the community account as the My account for possible rewards and connections.
HI @omorphi
only CS agent can help to change the Community name.  So, please submit a ticket for agent to assist with that
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
LitlLdy
@omorphi , only a CSA can change your community name! Sorry. You would need to submit a support ticket & ask them nicely to do it for you. 🙂
Click here to get started and type Customer Support Agent, then select Contact Us, then select the topic that matches your request.
Watch for a response back from a CSA in your Community private mailbox at the top right of this page which will be indicated by a number on the small envelope icon to the left of your Community avatar.
Edit: Don’t type “Change community username” or it will say “Unfortunately, Community usernames cannot be changed. 😥” I tried it & that didn’t work! So please type “Customer Support Agent”, Select Contact Us, Select “Other”, Select “Click here to submit a ticket “.
