How long does the$30 2 gig plan last.
ECHuss
mimmo
All current plans last 30 days then need to be renewed.
PM used to have  90 and 10 day plans but they are no longer offered. Some people do have these plans still as they were grandfathered.
totalUser
@ECHuss
Depends on your usage
It would last me about 4-5 months but I don't watch videos nor listen to music on it.
Most of people are fine with less than that during the month, so it's great option for that price if you don't want to worry about getting over your 1 gig on 25 plan.
You cannot purchase that plan anymore, bit you probably will be able in the future, this seems as reasonable price at the moment.
If you already have it and it suits you it's yours potentially forever as long as you don't charge it into something else
Triguy
Here is an article that gives an estimate.
https://whatsag.com/estimated-data-usage/data_usage.php
Hi @ECHuss ,
It will last as long as you do not change your plan...and that is because it is currently not an IN-MARKET plan, so if you change it, you will not be able to get it back.
That said, it may be available in the future (hopefully!). 🙂
