How long does it take to port in a number?
Stickyjonz
Last night I ported in my Freedom Mobile number to my existing PM account. The website said that the number change was successful.
But now, I have now been waiting close to 12 hours with neither service working. Why would it take so long?
7 REPLIES 7
CS_Agent
Customer Support Agent
Hello Stickyjonz,
Thank you for the update.
As the part of the Customer Service Experience, I am inviting you to fill the following survey:https://telus.eu.qualtrics.com/jfe/form/SV_6tzYQ56VOqX4teZ
Cheers
Abdoulaye
Stickyjonz
Sorry, I wound up getting everything worked out. Just forgot to mark this as solved.
CS_Agent
Hello Stickyjonz,
Thank you for reaching out to us.
In order to assist you about your port-in, please can you send to us a Private Message?
Cheers
Abdoulaye
PublicUser1
When I ported my number, I was initially only partially ported. After about 24 hours, the port was completed and fully functional. However, it was during one of the promotions, so I believe there was high traffic.
Hope this helps.
Just really depends on how many people have sent messages prior to yours. In times of promotions, wait times exceed 2 days, but since nothing is really going on in terms of promos (nothing major) you could hear back fairly soon
Stickyjonz
Thanks, I just sent a message. Any idea of the turn around after that?
xCameron94x
 Porting can be instant or a few hours. If your port is taking that long, it is possible that your port got stuck. So you should contact the mods
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
