08-30-2022 06:28 PM
I just recently activated a public mobile plan of $55 for 20GB.
As it is supposedly for a "limited time," how long can keep this plan? If this plan goes off the market, can I still use it or will I be forced to choose another plan?
New here, thank you in advance!
08-30-2022 11:15 PM
It will continue at $55 but you will lose the extra points. Look at the details of that plan.
08-30-2022 07:33 PM
@Timer wrote:when you activated and you get it that plan then will be in your account for ever for you have the service as long you keep same plan.
@Timer- This is false. Nothing is "for ever". Plans can and have changed. Forcefully no less. The company can change whatever they want whenever they want.
08-30-2022 07:26 PM
PM is much better at honouring grandfathered plan (the 10 to 13 issue aside). Carriers like Koodo and the other Big 3, not so much as they like to pull the rug out with some BS word salad and jack up their plans randomly with as little notice as possible.
08-30-2022 06:31 PM - edited 08-30-2022 06:32 PM
08-30-2022 06:31 PM
Plans come and go through the in-market offerings. If it goes away you should be able to have this plan for as long as you don't change it. But, once it is no longer available in their plan lineup, public mobile will not take it away from you.
08-30-2022 06:30 PM - edited 08-30-2022 06:31 PM
@tinagrit limited time just meant limited time to join. Once you are in, you are in. Of course, they can make change to it later. But it usually good for long time , PM usually does not touch existing plans (other than price increase , which can happen, but it happens very rarely 😀)
